After 3 days of constant troubleshooting, I need help, out of idea. I'll explain as best as I can. It started Saturday night, while watching Netflix, paused to get a drink only to come back to a BSOD: UNEXPECTED_STORE_EXCEPTION (154) (I will include the minidump). At this point, my first reaction is to do DISM.exe /Online /Cleanup-image /Restorehealth and then SFC /scannow. As I expected, I got the "Windows Resource Protection found corrupt files and successfully repaired them." Now I proceed to restart the PC and then run SFC /scannow a second time, as well as chkdsk on both drives. Everything turned out fine, so I stop troubleshooting and resume to play on the PC the rest of the night, without problems. Sunday morning, I was watching YouTube, suddenly the video froze as if it couldn't load, trying to quit full screen was unsuccessful and the PC just froze and then crashed: KERNEL_DATA_INPAGE_ERROR. I suppose then that I missed something on Saturday night and decide to go through the same process, this time though nothing was found. Going through the event viewer I couldn't find much substantial, but these two: "The device HID-compliant headset (location (unknown)) is offline due to a user-mode driver crash." "The RasMan service depends on the SstpSvc service which failed to start because of the following error: The operation completed successfully."
I checked the device HID-compliant headset, no errors were reported recently, nor any other peripheral associated. I'm running out of ideas, so I run a RAM test for 7 hours using Karhu Software. No errors. I did all updates available. Yesterday I cleaned my SSD, one more RAM test, chkdsk /f on both drives, more Windows updates, attempted windows repair, ticked off and then back on “Automatically manage paging file size for all drives”. Trying to check the minidumps myself was a failure, though I noticed two more minidump of the same UNEXPECTED_STORE_EXCEPTION (154) generated two and three months prior respectively, during weekdays while the PC was left unused. Right now all I get in event viewer is "The Driver \Driver\WudfRd failed to load for the device HID\VID_0951&PID_16A4&MI_03&Col02\7&1c94fa2&0&0001". Yet I found no problem with any drivers, whatsoever.
Still don't know if it will occur again, I assume the problem is not fixed. Considering I had two other BSOD of the same kind before, which I was not even aware of, make me think that.
https://www.mediafire.com/file/su372r9ioa7i6cm/121121-9812-01.dmp/file
www.mediafire.com
Specs:
Intel® Core™ i7-8700 3.20GHz
Nvidia GeForce RTX® 2070
16GB RAM (2x 8GB)
256GB SSD (Kingston)
2TB HDD (Seagate)
MediaFire
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Specs:
16GB RAM (2x 8GB)
2TB HDD (Seagate)
