SOLVED: New gpu solved issue!
My PC crashes a lot. Sometimes it can be 2-4 times a day and others nothing at all. The crash it self can happen at any time and lately I've gotten a white screen with a sound bug. Before I had a lot of vertical lines and usually green/black screen with a sound bug as well. Then I would have to hold the power button to shut off the system. The reset button works rarely. When I turn it back on the only problem is that I need to replug my wireless usb adapter each time as well.
I've never really managed to get a crash report but my event log says under critical;
41 Kernel-Power
and somtimes 404 Taskscheduler.
I've tried to doing a clean install of Windows 10 and updating drivers and so on. I've also disabled many sound/audio devices since it I've heard it can cause a bug or something since I somehow have many devices showing.
The reason I ask for help is because im planning on getting a new graphic card because I've read around that it might be the problem. I remember it crashed giving me a warning in windows before but fixed it with drivers I think. Then since I own a good GPU I will gonna put in a lot of money for a new one and if it doesnt solve it then it's hopeless.
Specs:
Windows 10
AMD Radeon R9 200 / HD 7900 Series
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
RAM - 16 GB
Silver power 750watt
NETGEAR WNDA3100v2 N600 Wireless Duel Band USB Adapter
Quick Updates:
1.
It shouldnt be a overheat problem because I can play high demanding games for tens of hours. The crash is 100% random.
CPU core temps are from 32-47 Celcius idle not doing much
GPU temp is 38-44 Celcius idle not doing much
Also stable on around 75 Celcius with Furmark!
2.
I've checked all the cables and found no problems with the connections!
3.
Also when I watch HBO pause it , turn the screen off and back on it's all green so I have to replug the HDMI (Not sure if this also adds more reason to swap my GPU out).
4.
Checked around in my BIOS and Turbo Mode was enabled overclocking the cpu to 3800 and the DRAM somewhat. I have reset BIOS settings and made sure the Turbo Mode is disabled. Now the PC makes almost 0 sound idle. Could this be the problem giving me the random crashes? I will update to see if there occurs any more crashes. (Still crashes 🙁)
5.
Memtest86 Summary:
Time: 3:24:49
Tests passed: 54/54 / 100%
Don't think there is anything with my memory. Could let it go longer but seems goods.
6.
Waiting for my new Corsair HX750i 750W PSU to see if it helps.
7.
New PSU installed. Still crashes!
8.
Tried to underclock my GPU to check if the problem still persists. (Still does)
9.
Ordered ASUS GeForce GTX 1080Ti ROG Strix Gaming. Been running fine for 4 days without crash now. All seems good.
41 Kernel-Power
Specs:
Windows 10
RAM - 16 GB
Quick Updates:
1.
2.
3.
4.
5.
Memtest86 Summary:
Time: 3:24:49
6.
7.
8.
9.
