Hi,
im running a i3-7100 3.9mhz, gigabyte geforce gtx 1050 2g and as a motherboard i got a asus prime b250m-a. i got 4gb ddr4 2400mhz ram stick and using a ( what i think) fairly old hdd thats about 2-3 years old. everything from cpu/gpu/ram/motherboard is bought very recently. only the hdd is a old part of the pc together with the psu/case but that doesnt matter to much. ive downloaded overwatch and world of warcraft and what i noticed is is when i run overwatch at 1080p low setings 75% render i sometimes get these weird frame drops that come out of nowhere. my pc is perfectly able to run these settings but what i do know is that i probably need atleast 8gb ram. even thought 4gb is enough what i notice is that my disk usage when i open a app or as i said playing games go to 99-100% a lot. my cpu is good temperature aswell as the gpu and the ram usage is okey its around 70-80% its on the edge but yeah its doable. do u know why my pc has these weird frame drops randomly. if any of you are able to help me or give me the right tips i would highly appreciate that. thank you. 😀
note: i manually downloaded motherboard drivers and since im an idiot with pc's i might've skipped something worth downloading. but this wouldn't cause frame drops if am correct? forgot to mention that the frame drops are from 120-150 fps to 30-50 fps wich causes my game to stutter and freeze for 1-2 seconds.
