Hello, I hope everyone is staying well and safe!
It has been a few days since I've had this issue. Randoms parts of both of my monitors start flickering with random colors. At first this happened when I entered a game, then it started happening even outside a game.
I have checked the cables of the monitors both are fine.
The flickering stops when I plug out the monitor using HDMI to DP cable.
Hardware info:
Monitors: x2 DELL SE2717H/HX (1080p, 27 inch, 75 Hz)
One of the monitors is with an HDMI cable, the other is with a HDMI to DP cable; Also I've set both monitors to 60 Hz hoping that would have some effect.
CPU: Ryzen 5 1600 - stock
GPU: RX 580 Powercolor Red Dragon - stock
MOBO: ASRock X370M Pro 4
PSU: HIPRO HPA-450W
RAM: 2x8 GB T-Force RGB @ 3000 Mhz
I hope all of this info is sufficient, if not, please do let me know what else I need to provide.
I am currently using a placeholder 6 years old phone and tried taking a photo, you can find it here: View: https://imgur.com/5PeVqiu
The colorful rectangle on the bottom of the photo is what happens.
Hardware info:
PSU: HIPRO HPA-450W
