Hi all, seems that there are a few other people having similar problems to me, thought I'd add my own thread rather than confuse or hijack someone else's!
I have a seemingly random issue where the power is completely cut from my system (as though you'd flicked the power switch on the PSU) an then restored a couple of seconds later - and the motherboard powers back on and the systems boots to the Windows logon screen. I have a Corsair PSU, and I noticed that the other people having similar issues did too - although of course they will likely be popular PSUs so it is probably just that. My system:
Corsair SF750 PSU (plugged into surge-protected 8-gang trailing adapter)
Maximus Gene VII + i7-4790k (not OC'd)
32GB Crucial RAM (not OC'd)
Samsung NVMe SSD (system drive)
3 x WD Red storage drives
RTX 2060 (Pailt StormX)
Asus Xonar PCI-E soundcard
I put this system together in Feb 2019, previously had an ancient CM Silent Pro 700 PSU and an H87 based board which never saw these problems (ironically I changed PSU because I read everywhere that the CM was known to be bad and might be a ticking time-bomb...). Since 2019 I have changed a few things, but this problem has always happened before and after these changes:
1050ti StormX -> 2060 StormX
16GB Crucual RAM -> 32GB
960 EVO SSD -> 980 PRO (I know this is completely superflouous for my system, but I felt like an update and wanted to future proof 😛)
PSU power cable changed from old Seasonic braided -> standard cable that came with SF750
From what I can tell my power requirements are well within the 750W limit of my PSU, plus I read somewhere on this forum that it can go to 900+W before giving up, so it shouldn't be overloaded. Also I can report that the fan doesn't spin beyond power-up when it does so briefly. Nothing else attached to the same trailing power adapter sees any problems, and it only has a few other things plugged into it (nothing major).
I've never seen anything in the event logs etc. other than "the previous shutdown at dd/mm/yyyy hh🇲🇲ss was unexpected" and this usually happens under minimal load (only firefox with <10 tabs open and simple browsing). I've never noticed a pattern in terms of when it happens. I have HD Sentinal running as a service and it has a green tick for all of my drives - plus drive, CPU and GPU temps are all good. These power cut-outs worry me mainly because I have some Veracrypt containers that I use for email etc. and I've had a few warnings regarding corruption as they weren't safely dismounted (lost my email program profile more than once). I have backups, but it is still a pain.
Is it significant that the motherboard boots back up again straight afterwards? I don't want to try it but from experience I'd expect this not to happen if I pulled the power cord and plugged it back in?
One last thing - might seem odd having the mobo + CPU combo I do if I'm not overclocking, but I just wanted the best setup possible on Intel 4th Gen so I can stay on Windows 8.1 until it dies (don't want to get into a debate about Win10, I'm just not a big fan of it). Got the Maximus Gene because I have a micro-ATX case (Silverstone TJ08-E) and I wanted a decent amount of SATA ports. But I did have stability problems at first, and these very forums helped me realise that the Maximus Gene overclocks by default (I think?) and I solved my problems by reducing my voltages (as per https://rog.asus.com/forum/showthread.php?51087-Maximus-VII-Hero-4790K-Temps-and-Voltages-Help). They were different problems too - they were as if someone pressed the reset switch on the board/case, as opposed to a complete cut of power. But I realise it could still be board related.
Any thoughts or advice would be much appreciated!
