System
PRO Z690-A WIFI
12700K
Kingston Fury Beast 32GB (2x16GB) 5600MHz DDR5
Noctua NH-U12A
WD Black SN850 1TB
ASUS Dual GeForce GTX 1070 8GB OC (running until I can get a 30 series card)
Fractal Design Focus G
Segotep 1000W Power Supply Fully Modular
Windows 11
So let me start out saying I am not a super in depth PC tech guy. I like to build PC's but I have a lot to learn. I am an industrial technician in my day job and do not work on computers for a living. That being said I put this PC together a few weeks ago. Ran some stress tests on it and all was good. When running Cinabench my CPU temp was up around 90c so I wanted to get a little better air flow through my case so I picked up 2 140mm case fans to replace the 120mm ones in the front of the case. I shut the computer down installed the new case fans and rerouted my cpu cooler wires. Fired the machine back up and went to run Cinabench to run my test. It ran for about a minute and the computer shut down and gave me a red cpu light on the motherboard. It automatically restarted and did the same thing.
The more times it restarted the less time it would run. So starting simple I unplugged the fans that I had just installed (no change). I then unseated everything from the mother board and reseated (no change). I cleared the CMOS this made the only change as cinabench ran for about 2 minutes. But I restarted it after that and it would barley start the test and shuts down. I am at a loss what to try next as I don't have any parts to throw at it because everything is so new. If anyone could give me some troubleshooting steps that would be great. Thank you.
PRO Z690-A WIFI
12700K
Noctua NH-U12A
WD Black SN850 1TB
Windows 11
