Hello everyone!
Before I get to it a little intro on the background of my current,
Ok-ish workstation with an threadripper 1900x on a MSI x399 SLI PLUS, cooled by a Noctua, with 64 of sloooow ram (got it to like 1400 with XMP) and a 1080 GPU.
To be honest I intended to do an upgrade on or a brand new workstation but reading that new Threadrippers are bit further down the road made me decide to build my first gaming PC. Prolly wanna do some basic OC-ing, don't rly plan to mess with custom settings but pre sent ones. Budget is not rly an issue as you might be able to already tell.
I'm looking to get the parts as fast as I can, once I set my sight on something I tend to rush to it to be honest I already found all the bellow listed parts localy for an acceptable price for me.
I am in no need for an OS, covered there, same as the monitor, got a nice Samsung 49'' ultrawide which I intend to use with the new build,
Spend a few days researching so before going rambo and just getting the parts right away , I decided to get some opinions first.
I decided to base the system around AMD, and since I'm a huge fan, Noctua, especially with the new 3070 Noctua edition GPU.
Additionally I started researching RAM since I wanna try to go for a higher speed and more optimized timings.
So here is what I came up with:
Processor - AMD Ryzen 9 5950X - pretty much set in stone
https://www.amd.com/en/products/cpu/amd-ryzen-9-5950x
RAM - DDR4 64GB (4x16GB), DDR4 3600, CL14, DIMM 288-pin, G.Skill Trident Z RGB F4-3600C14Q-64GTZR
https://www.gskill.com/qvl/165/166/1604305845/F4-3600C14Q-64GTZR-Qvl
timings&V: CL14-15-15-35 1.45V
this is a hard one for me, still don't fully grasp it but from researching and watching some videos i landed with these, tip/help welcome
they have quite low cas timings which aint greatly missmatched, and 3600mhz which seems to be the argued sweetspot for the 5950x on the internet ( i saw people saying between 3200 and 4000 but some claiming ryzen works better on the lower end)
MB - Asus ROG CROSSHAIR VIII DARK HERO, AM4, ATX, 4x DDR4, AMD X570, WL (90MB1760-M0EAY0) - suggestions, from my research the picked G.skill ram is compatible with speed and timings
https://rog.asus.com/motherboards/rog-crosshair/rog-crosshair-viii-dark-hero-model/
PSU - be quiet! DARK POWER 12 1000W - would like to know if i can get off with less W, would still take the dark power 12 tho, just less beefy
https://www.bequiet.com/en/powersupply/2151
Storage - Seagate FireCuda 530 2 TB 4.0 3D TLC NVMe - can't rly get my hands on the 4 TB one..
https://www.seagate.com/gb/en/products/gaming-drives/pc-gaming/firecuda-530-ssd/#
CPU cooler - Noctua NH-D15 Chromax Black - this one is set in stone
https://noctua.at/en/nh-d15-chromax-black
GPU - I honestly wanna get the new 3070 noctua edition but it doesnt seem it will be easy, so I'm rly open to suggestions here. I would like to upgrade/downgrade to the noctua one once i get my hands on it.
A random one i found on caseking and considering is the GeForce RTX 3080 TUF Gaming O10G, 10240 MB GDDR6X.
https://www.caseking.de/asus-geforc...F42j2Vk8WIDLugXJ0xzM-1636082772-0-gaNycGzNDpE
Case - I'm honestly still researching this, (might even opet to weld one myself down the road) in my opinion the cases out there lack exhaust fans,, but gotta deal with whats on the market, so my top contenders are the Fractal Design Torrent,, the Lian Li Lancool 2 Mesh,, Phantaks P400A and the Corsair 5000D AIRFLOW. If someone happens to know a case with more rear fans lmk!
Once I pick a case I plan to experiment with adding and replacing stock fans, ofc with Noctua. For example the rear fan with Noctua NF-S12B redux-1200 , some NF-P14s redux-1500 PWM on the top and or bottom an something like the reduxes or even NF-A14 PWM chromax.black.swap on the front. (you might laugh at me for this but its something i wanna experiment with and waste my time on X)
Thanks in advance for your ratings and suggestions.🍿
