Hi everyone,
I'm planning a new build consisting of the following:
(https://de.pcpartpicker.com/list/dMR4Mv)
CASE: Lian Li O11 Dynamic PCMR Edition
PSU: Corsair RM750i
MBO: ASUS ROG STRIX X570-E Gaming
CPU: AMD Ryzen 5900x
CPU COOLER: iCUE H150i ELITE CAPELLIX 360mm
GFX: TBD on Nov 18th
MEMORY: Corsair Vengeance RGB Pro DDR4 3600 4x8GB
SSD1: Patriot Viper SSD NVMe PCIe4.0 x4 M.2 1TB
SSD2: Mushkin Helix NVMe 1TB
CASE FANS: Corsair iCUE QL120 RGB
ADDED BLING: Lian Li Strimer Plus 24 & 8 pin
You are welcome to give suggestions or comments on the configuration itself but I am just wondering if the Lian Li strimer plus RGB will be controllable within icue software if connected to the RGB port on the Asus motherboard since the motherboard is compatible with icue. I will also get the icue controller bundled with the AIO cooler but it has 6 ports which will be taken up by the 3 radiator and 3 case fans. I am reading a lot about it but sill a bit confused as in does aura sync allow icue to control things that are plugged into it or just the motherboard rgb.
I'm really looking forward to your input and building this PC as a present to myself for xmas 😀
PSU: Corsair RM750i
