Rexper :
The next worthwhile step up, that’s in stock, from the Cougar VTX is the Corsair CX550M for 1800. Better performance, protections, build quality, cables, semi-modular.
Actually 1800 is too hot price for me, i'm not sure if i can even afford the Seasonic 520w with 1350 only, do you really think i can afford the 1800 :/ its impossible, told you previously make your recommendation within the prices of the 3 PSUs mentioned before so its between (1000-1400).
Anyways thank you so much for your help, for your time, for info, and for everything
not sure about what to go with, but if i could afford the Seasonic one i will go with it, otherwise i will choose between VTX500 and MWE that i don't think its bad, has nice protections, nice efficiency, nice fan type, nice hold up time... don't know where is the problem with MWE 500? not all bronze certified PSUs are worth to buy but its at least 80 Plus to ensure quality. MWE almost similar to Seasonic one from my perspective. all i can see an advantage for the seasonic one is the extra wattage and fan type, fan type is a little higher than with seasonic but also its not bad with the MWE.
The VTX one is great but that poor fan makes me worried because i usually spend too much time on using pc, if i take into consideration using the pc up to 20 hours a day, the fan will die after 4 years, using 16 hours a day, the fan will die after 5 years. that's my only worry.
With the seasonic one or the MWE, if i take into consideration 20 hours a day, fan will die after 6-7 years, for 16 hours per a day, fan will die after 8 years, and that's pretty good for me and maybe more than enough, even working for 24 hours the fan will die after 5-6 years ( 3 years only for VTX one :/ ).
Again more and more thanks for your time bro
