Rattling sound from H110i GT watercooler
TheDudeeee
14
Hi, my new watercooler makes this rattling noise (looked a bit on the internet and it seems like it's the fans that are crap) and I'm just wondering what fans I could buy that are 140m and are compatible with Corsair Link software since I want to be able to control the RPM on them? Or is it something else that's making the noise?? :??:
If it's your fans, it's easy to find out. Just open the case, then stop each fan with your finger. If the rattling stops, that's your source. Hopefully it's not your pump!
That said, if your brand new fans are rattling, let Corsair know. They aren't supposed to do that, and you do have a warranty.
