Raw Read Error and Multizone error rate is failing WD Lifeguard
InViTeD
8
Is this a bad drive? Im getting these values
Raw Read Error Rate is: 67 51
Multizone is: 200 51
Is this fixable?
No one NEEDS a HD... They need the data on it. Back up your data, get WD's diagnostic tools and test. If that shows errors, RMA the drive.
I dont have any data on the drive. And i have the WD diagnostic tools tested and have not got any luck with it.. Do you have yahoo so i can talk to you on there? Or AIM?
I was going to use the drive as a slave. So i could put some important information on it.. Thats why i Need the drive heh
No, nor di I have twitter, facebook or myspace. I like my privacy.
Just RMA the damned thing. My local supplier will swap out a drive no questions asked, then handle the RMA themselves.
Nice drive.... I hope you got it cheap. It'll make a nice paper weight, or you can remove the cover and turn it into a nice wall decoration.
Download the Ultimate Boot CD, burn an ISO, then try their drive formatting tools. May or may not help.
