Razer kraken pro v2 volume problem
sadpolk
Commendable
May 2, 2016
13
Hello evereyone,i got a problem with my headset.On particular volumes (changing the volume from the small wheel from the wire,not from windows)my individual volume for each ear changes as i hear only on one side or on the other depending on the volume,or either one of them has a different volume than the other.I got a dedicated sound board,asus sonar ds and my headset is razer kraken pro v2,but i have no ideea if the headset or the sound board is the issue.
Thank you in advance for your help!!
P.S.sorry for my bad english,i can give further explaination if needed.
Try adding hand sanitizer into Wheel of headset, probably due wear this issues is happening, try it on phone to be sure its headphones issues, if yes do trying to add hand sanitizer into Wheel just a little bit to lube it up, probably youre gonna need to open the plastic shield to add it propetly (where is the Wheel).
5years later can’t believe this hand sanitizer actually solved my headphones that i stoped using them because of this simple solution HAHAHA is so funny…thank you if u steal use this platform!
