Razer Mamba 2012 right-click stutter
Zaack Plays
24
Its been 3 months and this mouse cant keep hold on it's right-click, when i right click and hold, it leaves the click and re-clicks again and again, kinda stuttering, by this way playing my Black ops 2 require me to keep holding my right click to aim, which makes it very difficult and impossible to use the computer and play games. The support is not helping in anyway and i have searched half of the internet to get this solution. Yelp!
The issue can and will be located in your switch located under the right clicker. I can't suggest that you open it up and repair because often times it can be a better idea to get a new mouse of a different brand as you will have a somewhat profound distaste towards Razer peripherals snow. I've had the same thing happen to me with the Razer Spectre mouse which ran great for almost 3 years of gaming but their QC isn't on par with other makers of peripherals. My Razer Marauder has had it's lights shot to death so that keyboard is useless to work on.
Back on topic, if the issue you've stated is seen on other mice then you may want to take a look at your chipset drivers and if there are any BIOS updates available for your motherboard. Speaking of which, can you please pass on your full systems specs?
You may want to take a look at these videos;
https://www.youtube.com/watch?v=Vgh4co_tUMk
https://www.youtube.com/watch?v=-TlmAFG6a_o
I applied the same way but it didn't resolved but after a few days its good now. But now the clicking sound is silent, i discovered this when i was putting in the cotton swap on the click chip to clean it and it didnt make a sound, the left click makes perfect sound tho. Thanks.
