Razer's 14-inch Blade Goes Up for Pre-order
Yeah you are basically paying for that thin design and aluminum housing.
It is like buying a Cadillac. Pay more for a car that has the same engine as a car that is nearly half the price, but hey it sure looks pretty to some people.
it's a weird decision, but for more or less a pure gaming laptop, it makes sense. why? the GTX 765M can barely play the most intensive games at those resolutions at high settings, so making it 1080p won't make much of a difference
The website says, "The 14-inch Razer™ Blade is designed for gaming with essential gaming grade peripherals built-in." Yet, it's missing the Ethernet port. If you take gaming seriously, you're not going to play on-line games over WiFi.
An Ethernet port was not included because it simply cannot fit. An Ethernet port is too tall to be able to fit on the side of a laptop this thin. It does have 3 USB 3.0 ports though. If I'm gaming on a laptop I only need 1 for a mouse and maybe a second for a USB headset. That third could be used for a USB 3.0 to GbE adapter. An adapter may not be the ideal implementation but if you're using an Ethernet cable anyway then a 6" adapter won't be any more intrusive than the wire itself. It will work just as well as a native port and considering how portable this machine is I wouldn't have an issue with carrying a USB adapter in my bag alongside with my mouse and charger.
1600x900? That's just retarded at this price point. For $2,000, I sure as shit don't want to adjust/revert video options per application when plugging into an external 1080p display. That's some booshit right there, folks.
This product needs to have something to knock home why it's so expensive. Screen resolution? Mediocre. Graphics? Pretty good. Other Specs? Decent. Thinness? Damn good. For 2 grand I could buy something like a lenovo yoga and a good gaming rig.
it has a much shittier screen than the rMBP, but it has better specs and is slightly thinner than the 15 inch rMBP. if you call that even, it's also $100-300 cheaper than the rMBP. so yeah, technically it's priced right (by Apple standards lol)
