Question razor cynosa help
Smoker_2
153
Hey My razor cynosa Esc through f1 in f12 are not working all other keys do work When I press FN + f9 my top roll keys light up white please help
Do other keyboards work?
Does the Razor keyboard work on other computers?
Do you have the User Guide/Manual for the Razor?
Have you manually downloaded, installed, and reconfigured the keyboard drivers directly from the manufacturer's website?
(Do not use any third party tools or installers.)
[Moderator edit to break up one long sentence/paragraph.]
i tried it on my laptop in same thing it was working a few months ago
perfectly in other keyboards work on the same usb port
I have downloaded the new Razer Synapse 4
I tried to do a driver update but all it says is connect the device to your pc which it is
All lights work properly All other keys work beside the top roll
I even tried a hard reset esc caps and space bar
When I go to device manager it shows the razor keyboard is connected
but if I can't get it to work ill just buy a new keyboard
Not quite sure what you mean about the 4rd party software as I only downloaded the Razer Synapse 4 in tried the updater in it won't work
