[SOLVED] RDR2 Won't Launch when using dual-monitor
Indra Constantine
Commendable
Nov 4, 2021
15
So i use 2 Monitors with inputs
(Monitor 1) HDMI GPU
(Monitor 2) Onboard VGA
Dual Monitor WORK, but game RDR2 won't launch its only read on the taskbar. (other game work)
View youtube tutorial "disable display Intel HD in Device Manager" and YES game work, but the monitor can't 2 displays.
Now i wants to dual display with
But games run without issue, how I can do that?
Can you please parse the specs to your build/setup like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitors:
If you're on Windows 10, mention the version(not edition) of the OS. As for your issue, does the issue crop up with other titles?
Problem Solved:
You need go to "Setting in windows 10 > Game Mode > Graphics Settings > Browse and search RDR2.exe and change the option in there to Intel HD Graphics, dont worry about it, your game still will run in Your External GPU... not in Intel HD GPU
