reaccuring problem disk boot failure
r4kiad
4
It started after I received a blue screen while checking my fb, when I start up my computer it makes a weird clicking noise and most of the time it will click 3 times then it would go to a black screen that said "boot disk failure", I tried launching up bios setting but my keyboard would freeze in the middle of it and my mouse would work occasionally even though it is new mouse, I tried restoring it and it would work for that day but when I leave my computer on overnight, I would wake up to disk boot failure, help please
Sounds like your hard disk has failed. At this point I would suggest you get a new hard drive, disconnect the old one, install a clean instance of windows to the new disk. Once it is up and running you can try to reconnect the old drive and see if it can be accessed to retrieve the data and other files on it. I would stop trying to use the current disk immediately because repeated attempts to use a failed or failing disc can make any recovery of information on it more doubtful. You do not provide any system information so there is not much else to say. If you have never set up a system from scratch, it may be best for you to find a qualified service facility to do it for you. BTW what is a fb (Face Book)?
Thank you and yes it is fb, Idk if it would help but it is window Vista home premium
Thank you and yes it is facebook, Idk if it would help but it is window Vista home premium
