So after about a year of looking for parts, I finnaly think im ready to upgrade my cpu. Before I describe what I’m planning to do, I’d just like to say that I’m confident on the hardware exhange, but I’ve never had to wipe a harddrive, or reinstall windows or stuff like that.
I plan to go from:
Win 10
AMD Phenom ll x6 1100T
Some gigabyte mobo with loads of letters that I can’t remember atm
16GB DDR3 ballistix RAM
To:
Win 10
Intel i5 8600k
Some z370 mobo that I haven’t decided yet.
16GB 3000mhz Corsair vengeance ram.
So to do this, I’m going to move my images and documents, gamesaves etc from my 1TB OS drive, to my 3tb drive, so that I can then wipe the 1TB drive.
I got windows 10 from when it was free a couple of years ago, and I have linked it to my MS account.
So instead of spending £120 on a new windows 10 key, can I download a windows 10 image from the Microsoft website, put it on a usb, then use that to reinstall windows onto the 1TB after I wiped it, and then log into my Microsoft account, so that it restores my stuff and I don’t have to pay for a new key.
Also what happens to my graphics drivers?
I know that when you upgrade from an amd gpu to a nvidia one or visa Versa, you have to download the new drivers, then uninstall the old ones, then turn off your pc, do the exhange, and then boot in safe mode, to install the new drivers, would the process be the same here? As in download and install my gpu drivers in safe mode.
So my plan as I understand it would be to do this:
Move personal files from 1TB OS drive to my other one.
Download a win 10 image from Microsoft and put it on a usb drive.
Double check that my windows key is linked to my ms account.
Close down PC
Use a different pc to wipe my 1TB OS drive.
Do the hardware exhange of mobo cpu and ram, reconnect 1TB os drive.
Turn on pc, install windows onto the 1TB drive.
Boot into safe mode (?) link this new windows version to my ms account so that it unlocks, download nvidia graphics drivers, install, restart into normal mode.
And then I’m done (?)
Cheers.
I plan to go from:
Win 10
To:
Win 10
Intel i5 8600k
Close down PC
Cheers.
