hi guys,
ill be changing my motherboard,cpu and ram on my old hp pavilion pc....when i opened up my case to do some checking,i found the following connectors on the mobo(the ones im confused about)-
1.front panel connector-for the power switch right?
2.THIS ONE IS REALLY CONFUSING ME-one connector is labelled JUSB2(has 8pins),coloured white and has a cable attached to it which uses up 4 of the 8 pins...i dont get what that one is for...it seems to be coming from the same place the front panel cable is coming...what is this one for?(the front panel usb ports are already connected to a JUSB1 port)
im changing the mobo to an asus h81m-cs but im not sure where the above cable would go in...please help me out...
Thanks
Thanks
