Hello there.
Recently I installed Harman Kardon's Soundsticks unto my PC.
The problem I'm going to describe started from the moment I installed the new Soundsticks.
What happens, is after some time when I don't touch my PC (5 mins? not sure), sounds will cease working, unless I "wake" it back up by trying to play sounds. Then, it takes about 5 seconds for the sound to come back up.
This is extremely annoying - and frustrating. I had a similar problem with my Keyboard, where after 10 seconds if not touching it - it "turned itself off", and when I reclicked it, it continued working again. I fixed that problem by disabling power management for the keyboard.
Sadly! I cannot find, anywhere, any option in device manager or anywhere else, an option to disable Power Management, which I suspect is causing my speakers to not work after I leave my PC alone for a bit.
I'm using my PC for alerts sometimes, which is extremely annoying, because since the PC was idle, the alert sound will not pop off because of this annoying bug.
Please help me!
Please help me!
