Realtek Rtl8191su Connection Issue
Sirprodigy
22
As stated above I have a realtek rtl8191su, and can connect to any WiFi network BUT mine.I recently exchanged my belkin router (no problems) for the new xfinity router/modem mix.I cant connect to it because of some type of "DNS" issue.I can connect to any other WiFi without fail to my knowledge.Any suggestions or help?
ISP:Comcast
OS:W7
I've been battling the same problem since about 9/15/14. Same card, same Xfinity router, same WIndows problem, but I'm in windows 8.1. Try going into the Device Manager, finding your card under Network Adapters, right click and go to properties. Under the Advanced Tab, see if you can change your Wireless Mode to b/g. Doing that I was able to connect for a while, but that obviously had it's own set of problems. If I ever had wireless n engaged, I could not connect to the xfinity router.
The...
Sirprodigy
22
sorry I should have been more clear.The rtl8191su is the USB receiver.My router/modem combo is brand less to my knowledge and given to me from Comcast.
CRNR-OFCE
The only solution that seems to be working thus far was to force install the Wireless Lan Utility by Realtek (from two years ago), and try to install the drivers as well.
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PFid=48&Level=5&Conn=4&ProdID=229&DownTypeID=3&GetDown=false&Downloads=true#2291
When I first did this, I think Windows updated the drivers automatically and I lost the one that I installed. At least now my system is reporting wireless n is working. I'm going to work on it more in the future if it's bothersome. I have a suspicion there's either a problem in either the latest Windows drivers, or the Xfinity firmware.
