Rear audio ports bad sound ASUS Z97-c
dazk123
I've been using the front audio ports for my pc since i bought it 2 years ago and the audio was just amazing, i never even tried the rear ones until now that the front ones stopped working, don't know why, when i decided to try the rear ones i noticed that the sound is terrible compared to the front ones, it sounds muffled and low, is there something i can do about it? is the rear audio on this specific motherboard just that bad? i would like to know if you guys have any input on this, i would really appreciate it.
Hello thx for replying, what exactly do you mean that's not possible? yes i am using the green port although im not quite sure what you mean by selection output to front panel, i'm using the realtek drivers, should i uninstall them or do something with them you mean?
