It depends on what type fan the case manufacturer will install, it can be 3-pin, 4-pin, or molex. And you can remove that fan, put it on the top or in the front as long as it can fit in there.Normally does rear case fan have molex connector or 3 pin connector?
Can that fan be removed and installed on the top of the case?
