L Lil___ Commendable Dec 15, 2016 54 0 1,630 Mar 31, 2017 #1 I have a Dell XPS 8700 and want to put in a new rear fan. Would I be able to do it?
Solution Dark Lord of Tech Mar 31, 2017 Yes you can change it , just make sure it's the same size as the stock one.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Mar 31, 2017 Solution #2 Yes you can change it , just make sure it's the same size as the stock one. Upvote 0 Downvote Solution
L Lil___ Commendable Dec 15, 2016 54 0 1,630 Apr 2, 2017 #3 Yes you can change it , just make sure it's the same size as the stock one. What pin would I need (4pin, 3pin, etc Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,779 3 61,010 Apr 2, 2017 #4 Look at the header on the mobo that it's connected to. Or look at the end of the fan it's either 3 or 4 pin Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Apr 2, 2017 #5 Lil___ : Yes you can change it , just make sure it's the same size as the stock one. What pin would I need (4pin, 3pin, etc Usually they are 3 pin. Upvote 0 Downvote
