i7 8700k
MSI RTX2080
G SKill Ripjaws V 16GB DDR4
EVGA SuperNOVA 850 G2
So rig was running great with a gtx 1080. Upgraded to Gigabtye 2080, didn't like the software. About that time I upgraded to the MSI 2080 and also updated Windows for the October update. FPS in games like D2 have dropped in certain areas. Titan I'm getting 65 FPS at main load in place, used to get a lot higher. Changing from 1440p to 1080p doesn't change the FPS at all. CPU sitting at 30% and GPU at 46%. Issues in fornite where dropping from bus when lots of people load in FPS goes from cap of 160 to 90ish. Changing resolution from 1440 down to 1080 doesn't affect this either. I know when I upgraded to 2080, which included a new 1440 monitor, i tested fortnite and it ran great. I've already changed out this MSI 2080 with another, so thats not the problem. I've done the typical DDU uninstall and reinstall. Tried all of the drivers available for the 2080. Nothing changes it. Memory load isn't too high or anything. Just really confused with low usage, low fps, and resolution having no impact. In other areas of the game it will run just fine, max out load and high cpu usage. Im at a loss, please help!
Edit: also cant roll back windows, some dummy deleted the old files
. Tried the fresh install option too, didn't change anything.
MSI RTX2080
