T tryissesf2 Prominent Jan 6, 2018 4 0 510 Jan 6, 2018 #1 Hi, I wanna know the cheapest Intel CPU that performs same or better than i7-4770K as I mentioned in the title. It must be either Skylake or Kaby Lake.
marksavio Estimable Dec 23, 2017 1,679 5 2,960 Jan 6, 2018 #2 well i can only think of the i7-7700K if you are fine without the overclock then go for the non-k version. and its $200 cheaper Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Jan 6, 2018 #3 6700k or 7700k. If you consider coffee lake then 8400/8600k/8700k Don't know where you are from or what prices are like where you are. Upvote 0 Downvote
T tryissesf2 Prominent Jan 6, 2018 4 0 510 Jan 6, 2018 #4 sizzling : 6700k or 7700k. If you consider coffee lake then 8400/8600k/8700k Don't know where you are from or what prices are like where you are. I'm from Turkey and in here i5-8600K and Z370 combo cheaper than i7-7700K/i7 6700K and H110M combo. And I guess I will go with i5-8600K. Upvote 0 Downvote
trollzhxtroll Prominent Aug 22, 2017 192 0 760 Jan 6, 2018 #5 7700k. or i5 6600k, it's very good for overclocking Upvote 0 Downvote
T tryissesf2 Prominent Jan 6, 2018 4 0 510 Jan 6, 2018 #6 marksavio : well i can only think of the i7-7700K if you are fine without the overclock then go for the non-k version. and its $200 cheaper They are almost same price in Turkey, unfortunately. Upvote 0 Downvote
marksavio Estimable Dec 23, 2017 1,679 5 2,960 Jan 6, 2018 #7 im glad the coffelake prices are cheaper for you over there. 😀 good deal man Upvote 1 Downvote
T tryissesf2 Prominent Jan 6, 2018 4 0 510 Jan 6, 2018 #8 I also want to know that how i7-6700K is better than i7-7700, what is the difference between them except their base freq.? Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Jan 6, 2018 #9 tryissesf2 : sizzling : 6700k or 7700k. If you consider coffee lake then 8400/8600k/8700k Don't know where you are from or what prices are like where you are. I'm from Turkey and in here i5-8600K and Z370 combo cheaper than i7-7700K/i7 6700K and H110M combo. And I guess I will go with i5-8600K. That's good, the 8600k & Z370 is a better setup. Upvote 0 Downvote
