Question Recommendation for a socket AM5 motherboard ?
Amigo1982
73
Please recommend me an exact model motherboard to support the following
AM5 socket
PCI-E 5.0 and M.2 Gen 5
WAKE UP THE PC FROM USB MOUSE - TO POWER ON THE PC WHEN I CLICK THE MOUSE
Not just in BIOS boot from any USB device. Because the computer is connected also with 2 USB keyboards and i do not want key press to start the computer. I want specifically from USB mouse to power on the PC
I have had Asrock Z170 with Intel I7 7700 CPU to support exactly that - power on by USB mouse - it does not works always fine That feature is not supported in most of newer Asrock boards
Now it is time for another CPU 7700 - this time for AMD and i am searching for a motherboard.
Asked Gigabyte support - so far a few days no answer.
If possible not the most expensive model please. But i see that X670 chipset should be because B650 does not support Gen 5 PCI and M.2
Please guys - i need to buy a new motherboard these days.
What's your base budget rn........................cuz I'm partnered with ROG and could get you a good AM5 Mobo even though my main focus is on Intel
