Recommendation on best compact Mid Tower (ATX size case)
stevenh777
31
Hi, can anyone recommend me a compact pc case for atx size motherboards?
Ideally looking for a case with mesh panels for better airflow, as well as a tempered glass side panel. Not too worried about price, £120 would be my max budget.
As far your case selection goes, you need to figure it out by yourself since choosing a PC case is a personal choice. Go with the one that you like the most. I can only give you additional suggestions regarding cases with tempered glass side panel, like:
Note: In brackets, ( ), is CPU cooler clearance.
Corsair lineup:
Spec-04 TG, (150mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Carbide-Series%C2%AE-SPEC-04-Tempered-Glass-Mid-Tower-Gaming-Case-%E2%80%94-Black-Red/p/CC-9011117-WW
Spec-06 TG, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/SPEC-06/p/CC-9011144-WW
Spec-06 RGB TG, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/SPEC-06-RGB/p/CC-9011146-WW
Spec-Omega, (170mm)...
Corsair lineup:
Spec-Omega, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/SPEC-OMEGA-CONFIG/p/CC-9011120-WW
Spec-Omega RGB, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Carbide-Series-SPEC-OMEGA-RGB/p/CC-9011141-WW
275R TG, (170mm): https://www.corsair.com/eu/en/Color/Carbide-Series-275R-Tempered-Glass-Mid-Tower-Gaming-Case/p/CC-9011132-WW
280X, (150mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Crystal-Series-280X/p/CC-9011134-WW
280X RGB, (150mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Crystal-Series-280X-RGB/p/CC-9011135-WW
460X, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Crystal-Series%E2%84%A2-460X-Compact-ATX-Mid-Tower-Case/p/CC-9011099-WW
460X RGB, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Crystal-Series-460X-RGB-Compact-ATX-Mid-Tower-Case-%28CN%29/p/CC-9011101-CN
500D, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Mid-Tower-ATX-Cases/Obsidian-Series%C2%AE-500D-Premium-Mid-Tower-Case/p/CC-9011116-WW
500D RGB, (170mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Obsidian-Series-500D-RGB-SE-Premium-Mid-Tower-Case/p/CC-9011139-WW
570X RGB, (170mm): https://www.corsair.com/us/en/Categories/Products/Cases/570x-rgb-config/p/CC-9011098-WW
1000D, (180mm): https://www.corsair.com/eu/en/Categories/Products/Cases/Super-Tower-and-Full-Tower-Cases/Obsidian-Series-1000D-Super-Tower-Case/p/CC-9011148-WW
Phanteks lineup:
Eclipse P300 TG, (160mm): http://www.phanteks.com/Eclipse-P300-TemperedGlass.html
Eclipse P350X, (160mm): http://www.phanteks.com/Eclipse-P350X.html
Eclipse P400 TG, (160mm): http://www.phanteks.com/Eclipse-P400-TemperedGlass.html
Eclipse P400S TG, (160mm): http://www.phanteks.com/Eclipse-P400S-TemperedGlass.html
Enthoo Evolv ITX TG, (200mm): http://www.phanteks.com/Enthoo-Evolv-ITX-TemperedGlass.html
Enthoo Evolv mATX TG, (192mm): http://www.phanteks.com/Enthoo-Evolv-mATX-TemperedGlass.html
Enthoo Evolv ATX TG, (194mm): http://www.phanteks.com/Enthoo-Evolv-ATX-TemperedGlass.html
Enthoo Pro TG, (193mm): http://phanteks.com/Enthoo-Pro-TemperedGlass.html
Enthoo Pro M TG, (194mm): http://phanteks.com/Enthoo-Pro-M-TemperedGlass.html
Enthoo Lux TG, (193mm): http://phanteks.com/Enthoo-Luxe-TemperedGlass.html
Almost all cases listed here support ATX sized MoBo. Also, most of them are within your budget as well. Though, since list includes all tempered glass side panel cases from Phanteks and Corsair lineups, it also contains full-tower ATX cases which are too big for your preference (e.g Enthoo Lux TG).
