Recommended CPU cooler for i5-4690k?
KingZombie
29
What cpu cooler would you recommend for the i5-4690k if i want to hit 4.5Ghz and have good temps while on load?
Would either of these coolers be good for overclocking it @ 4.5Ghz?
Noctua NH D15
Corsair H80i
Corsair H105
Corsair H100i
I'd recommend the Noctua NH D15, the noise-cooling performance is good, and air cooling is more reliable than the AIO watercooling kits.
All of those will do what you want. The Noctua is the quietest if that's what you're looking for. The Be Quiet! Dark Rock Pro 3 performs similar to the Noctua NH D15 and you might get one cheaper depending on where you are.
This applies to all of them, make sure to check the measurements to make sure it will fit in your case. All of these are fairly large.
