Recommended Motherboard replacement?
Tabs467
7
I currently have a GTX 1070 and an AMD CPU and AMD Compatible motherboard but I am looking to swap the CPU for an i7 7700k. Which motherboard do you recommend i buy to go with it, I am looking for a fairly cheap one that will fit in my case.
Case link: https://www.aria.co.uk/Products/Components/Cases/Midi+Tower/BitFenix+Comrade+Midi-Tower+-+Black+?productId=59627
Also as a side question will my 500W power supply be enough to support this system?
Power Supply Link: https://www.aria.co.uk/Products/Components/Power+Supplies/Non-Modular+650W+or+less/EVGA+500W+80+Plus+Power+Supply+(100-W1-0500-KR)+?productId=60504
You will have to replace the motherboard, CPU and RAM all at the same time unless you have a Ryzen AMD CPU. Then you could keep the RAM.
