Z zatchbell622 Reputable Aug 14, 2015 1 0 4,510 Aug 14, 2015 #1 I need to reinstall my stock GPU but I cannot find where to plug in the power inside the computer. They are blocky, with six prongs. The GPU has no place to plug these in. PLEASE help.
Solution Someone Somewhere Aug 14, 2015 The PCIe slot supplies some power. For many low-end GPUs (including probably yours; OEM ones are hard to find data on), this is enough and no cable direct from the PSU is needed.
Someone Somewhere Titan Sep 23, 2012 22,291 8 84,965 Aug 14, 2015 Solution #2 The PCIe slot supplies some power. For many low-end GPUs (including probably yours; OEM ones are hard to find data on), this is enough and no cable direct from the PSU is needed. Upvote 0 Downvote Solution
