Hi,
i bought a brand new msi 450 gaming plus along with other brand new components and build it all together today.
when i try to switch the power on at the back of the pc, a red light in the upper left corner of the mainboard starts to blink and does so 3 times in total, then it stops.
When i push the power button in front of the pc to turn the pc on, the graphic cards lights (the sapphire logo) go on for a very brief moment (maybe half a second), then off again.
No fans are starting to work, no sounds are coming from the motherboard.
It seems that the pc is not even starting.
All components are brand new and have been plugged into the motherboard as they are supposed to be, according to the manual.
i double checked cpu and ram and they are in place appropriately, all cpu pins are straight.
cpu: ryzen 5 2600
ram: 2x 8gb aegis 3000mhz ram
graphics: sapphire radeon nitro+ 8gb
power adapter: bequiet! 11 500 watt
im pretty much desperate, because i have no idea what to do and i bought the components from different vendors and i dont know which component i would have to send back, if any.
Any help or ideas to make this pc work would be much appreciated !
cpu: ryzen 5 2600
