Question red dead redemption 2 issues and bex64
sergioalbertocmarin
76
4
18,535
ive encountered so many crashes with this game from :err_gfx_state rdr2, err_dfx_referr memory, one blue screen of death, and BEX64.
and its not like my system is weak either:
ryzen 5600x, b550m aorus elite, psu xpg core reactor 750w, rtx 4070, 32 gb ram ddr4 3200, game installed on nvme 1tb, win 10 pro.
currently using vulkan since dx12 is just no go, it doesnt work.
i also got this bex error with EA launcher today
View: https://imgur.com/a/RDwjbfp
View: https://imgur.com/a/e62t7Ec
i also recently installed this https://support.microsoft.com/en-us...-preview-0ae14f06-577e-4eb3-8fcb-c722f3f9dc29
cause someone suggested it that it would fix the problem with game stuttering, but im starting to wonder if when i installed this the BEX64 started to arise.
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
Reset the BIOS by jumper clrCMOS or JBAT or similar (eventually you will have to set the boot priority correctly after that)
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool and if available, update the firmware
use ddu uninstaller and reinstall the latest graphics driver
Also look in Reliability History/Monitor and Event Viewer for other error codes, warnings, and informational events.
Objective being to discover what Windows/Microsoft is capturing when the game crashes.
clean boot
View: https://imgur.com/a/pmY6dWV
i tried doing the test but for some reason it ends like that im not sure if im doing something wrong here
