Red LED Light for power button on 760T
binarycoder1010
Commendable
Aug 31, 2018
21
Hi guys!
So I have a 760T for the case, I recently had a Mobo and CPU upgrade from a Z270 to a Z370 and a 7700k to an 8700k. The light use-to be white for the power button but now it's solid red for some reason. This happened after I had my new hardware installed.
https://streamable.com/rzduj
Specs:
2x EVGA GTX 1080's
850 Watt - EVGA SuperNOVA 850 - 80 PLUS Bronze
16GB RAM (not sure if brand matters)
DEEPCOOL Captain 240EX 240mm Liquid CPU Cooling System
I had my PC pre-built by iBP
Let me know if you guys have any ideas of if I should be concerned or not. As far as performance goes everything seems to be working fine. Thanks! :-]
There's a chance you might've plug the wrong pin connectors for the front I/O ports of the case into the motherboard and this is causing some ground on the front led power/reset buttons.
This is just a reference:
