So i recently bought parts for my new pc.
The specs are:
Be quiet 500dx case
MSI MPG x570 gaming plus
32gb 3000mhz g.skill ram
Ryzen 5 5600x
RTX 3060 Ventus 12gb
750 be quiet psu
500gb m.2 ssd and 2tb hdd.
So my problem is that when i finished building the pc i went to turn it on and saw that the RGB Lights turned on. But the fans werent spinning and there were 2 Red Lights on thr VGA and DRAM at the EZ Debug LED. So i did some troubleshooting my placeing the new gpu in my old pc which worked fine. I tested the ram which didnt seem to be a problem with. So my conclusion was the CPU. On the MB box it says "AMD Ryzen 5000 series desktop ready" but i then tried to flash the bios for the motherboard as to update it. As i put the USB the lights turned on and the BIOS light was blinking red. Then i waited till the BIOS light turned off. Then i turned off the Power on my PC and restarted it. I then saw there was a red light at the CPU on the EZ Debug LED. I then reseated the CPU and tried to turn it back on but it didnt work. I did this without the CPU fan screwed on. So is it a faulty CPU? Or could there be another problem?
The specs are:
Be quiet 500dx case
Ryzen 5 5600x
750 be quiet psu
