Question Red X in my Audio icon
RacerBoss
12
Hello, I have accidentally deleted High Definition Audio Device and then it shows a Red X. Any ways to get it back? Please reply soon...
Well the thing you deleted, is a driver, a software that gets your pc to output sound. When you restart your pc (connect it to the internet), Windows usually auto-downloads required drivers
YESS IT WORKED THANK YOU! Well but I decided to run youtube, still sound doesnt come, any solutions?
I mean the red x is gone and the audio is back to normal but it doesnt run tho when i run some audio ;-;, How to fix??
right click on speaker icon on taskbar, click sounds, go to playback, set whatever you're using as default, check volume and if it is muted
k nvm i got to playback but why to set it as default??
Well I have checked everything nothing is muted, all r normal.. What to do?
