I recently purchased a XFX 6870 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561) and it works great except I would like to drive the noise level down. I've set up a fan profile in Afterburner so the noise is reasonable at idle or low load. However it starts imitating a vacuum sweeper when I'm gaming.
My question is whether adding side fan(s) to my Rosewill Challenger Black case will help reduce the cards temp therefore noise or whether I would be better off adding an aftermarket cooler for the GPU? Please suggest specific models. My budget is absolutely no more than $30 (before rebates) but the lower the better.
Thanks.
Thanks.
