I currently have a 1080p monitor, so SLI isn't needed, but I plan on getting a 1440p monitor. When I get a second GPU should I get a Reference design card? If I got a reference card it would be the EVGA FTW.
I currently have a EVGA GTX 670 FTW 4gb which is a GTX 670 clocked to the speed of a stock GTX 680 with the GTX 680 cooler. My case is a NZXT Tempest 410 Elite http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080
And for a Non Reference GPU it would need to be a GPU factory OCed to at least 1006 on the core clock, or a Asus Top GPU with 4gb of Vram, so what ever you recommend.
Thanks!
Thanks!
