Regedit for CTRL+ALT+DEL logon
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Does anyone know how I can use regedit to enable the old type ctrl+alt+del
logon? Any help apreciated.
Roger
1. Open User Accounts in Control Panel.
2. Click the Advanced tab.
3. In Secure logon, select the "Require users to press Ctrl+Alt+Delete" check box.
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
| Roger
> check box.
Thanks for the advice, but something have denied me the access to the
controlpanel allthough I am the administrator, so hence the question for
the regedit command
Roger
Do scan with an up to date anti-virus.
What You Should Know About Spyware
http://www.microsoft.com/athome/security/spyware/devioussoftware.mspx
CAUTION!!!!! Removing some spyware can damage the Winsock stact. Before
you try to remove spyware using any of these programs , download a copy of
LSP-Fix - a free program to repair damaged Winsock 2 stacks (all Windows
versions)
http://www.cexx.org/lspfix.htm
Winsockfix for W95, W98, ME, NT, 2000, XP
http://www.tacktech.com/pub/winsockfix/WinsockFix.zip
Directions here: http://www.tacktech.com/display.cfm?ttid=257
WinXP:
Get WinSockxpFix
http://www.spychecker.com/program/winsockxpfix.html
How to Reset Internet Protocol (TCP/IP) in Windows XP
http://support.microsoft.com/kb/299357
In WinXP SP2: You can fix Winsock by going to Start | Run and typing
CMD
In the command window type
netsh winsock reset
See
Dealing with Unwanted Malware, Parasites, Toolbars and Search Engines
http://mvps.org/winhelp2002/unwanted.htm
Note that AdAware and SpyBot S & D will each catch some things the other
won't. Also, each needs to be updated with the program's update function
before every use, even when just downloaded. There's also a lot more to do
than just those two programs. CWShredder is also available here:
http://www.intermute.com/products/cwshredder
**Post your HijackThis log to
http://forums.spywareinfo.com/
http://forums.tomcoyote.org/
http://castlecops.com/forum67.html
http://www.wilderssecurity.com/ or the Spyware forum at
http://aumha.net/viewforum.php?f=30 for expert analysis, not here.**
Alternative download pages for Ad-Aware, Spybot, HijackThis and CWShredder
may be found on this page:
http://aumha.org/a/parasite.htm.
See this link for information about malware:
http://arstechnica.com/articles/paedia/malware.ars
If nothing there helps, please post back to this thread.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com/security/protect/
"Roger Grønnvold" <gronnvold.roger@nospam_c2i.net> wrote in message
news:nntMe.4162$qE.999386@juliett.dax.net...
>> check box.
> the regedit command
> Roger
Hi Roger,
Restore the Control Panel - Line 256:
http://www.kellys-korner-xp.com/xp_tweaks.htm
Are you running XP Pro or Home? If Pro, go to Start, Run and enter
GPEDIT.MSC Go to User Configuration, Administrative Templates, Control
Panel, Display. In the right pane, locate the entry for Remove Display in
Control Panel. Double click this entry. It should be set to Disabled or
Not Configured.
If you're running XP Home, or if GPEDIT shows that this policy is Disabled
or Not Configured go to Start, Run and enter REGEDIT Navigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
Look in the right pane for a value called NoDispCPL. If present, double
click it and set its value to 0 (zero). If its not there, right click in
the right pane and select New, DWord value. Name the value NoDispCPL and
leave its value at 0.
Added info:
Key: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\
CurrentVersion\Winlogon]
Value Name: LogonType
Data Type: REG_DWORD (DWORD Value)
Value Data: (0 = Classic Mode, 1 = Welcome Screen)
Create a new DWORD value, or modify the existing value, called 'LogonType'
and edit the value according to the settings below.
Exit your registry, you may need to restart or log out of Windows for the
change to take effect.
Note: Using the classic logon method will also disable the use of fast user
switching, where applications remain active in other users sessions.
Enable or Disable Ctrl/Alt/Delete (Line 198)
All the Best,
Kelly (MS-MVP)
Troubleshooting Windows XP
news:q_sMe.4158$qE.999275@juliett.dax.net...
> Roger
