Question Relation between Sabrent and Micron/Crucial?
Jan 13, 2023
9
Hi all,
I've looked around a bit at this and cannot seem to find much besides, in search, that Sabrent and Micron Technologies are two entirely separate companies. Bing AI gives this, not particularly specific info:
"Micron Technology competes with other companies that design and manufacture memory and storage products for various applications and markets, such as Intel, Samsung Electronics, Western Digital, etc. Sabrent is more focused on designing and manufacturing storage products such as SSDs which may compete with some of Micron Technology’s products, but not all of them. "
I bought a Crucial MX500 1TB for my wife's older machine to replace the stock HDD. In using AOMEI Partition Assistant, the MX500 shows up as Disk Model: Sabrent
Can anyone explain this?
I know Crucial is under Micron. Sabrent seems to be its own company though. I mean, does it matter in the end? No. But I like to know who's who. Sabrent branded drives are more expensive than Crucial branded, but if they are identical, then it makes sense to go with the cheaper branding, hence the reason I ask. It also helps others in making informed decisions to save money, IMO.
Is the drive in an external enclosure? How does CrystalDiskInfo detect it?
In CDI you can redact the serial number (Function -> Hide SN).
Select Edit -> Copy Option and tick everything.
Select Edit -> Copy.
Then paste the clipboard contents into your next post.
Code:
CrystalDiskInfo 8.14.2 (C) 2008-2022 hiyohiyo
                                Crystal Dew World: https://crystalmark.info/
    OS : Windows 10 Professional [10.0 Build 19045] (x86)
  Date : 2023/02/20 7:37:27
-- Controller Map ----------------------------------------------------------
+ ATA Channel 0 (0) [ATA]
   - CT1000MX500SSD1 ATA Device
   - Generic IEEE 1667 Probe Silo
   - Microsoft TCG Storage silo
   - Generic IEEE 1667 ACT
+ ATA Channel 1 (1) [ATA]
   - Samsung SSD 860 EVO 1TB ATA Device
+ Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0 [ATA]
   - ATA Channel 0 (0)
   - ATA Channel 1 (1)
- Microsoft Storage Spaces Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(01) CT1000MX500SSD1 : 1000.2 GB [0/0/0, pd1] - m2
(02) Samsung SSD 860 EVO 1TB : 1000.2 GB [1/1/0, pd1] - sg
           Model : CT1000MX500SSD1
        Firmware : M3CR043
   Serial Number : ************
       Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 1953525168
   Rotation Rate : ---- (SSD)
       Interface : Serial ATA
   Major Version : ACS-3
   Minor Version : ACS-3 Revision 5
   Transfer Mode : SATA/300 | SATA/600
  Power On Hours : 586 hours
  Power On Count : 7 count
     Host Writes : 1109 GB
     Temperature : 30 C (86 F)
   Health Status : Good (100 %)
        Features : S.M.A.R.T., APM, NCQ, TRIM, DevSleep
       APM Level : 00FEh [ON]
       AAM Level : ----
    Drive Letter : D:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 __0 000000000000 Raw Read Error Rate
05 100 100 _10 000000000000 Reallocated Sectors Count
09 100 100 __0 00000000024A Power-On Hours
0C 100 100 __0 000000000007 Power Cycle Count
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD 100 100 __0 000000000002 Average Block-Erase Count
AE 100 100 __0 000000000004 Unexpected Power Loss Count
B4 __0 __0 __0 000000000043 Unused Reserve NAND Blocks
B7 100 100 __0 000000000000 SATA Interface Downshift
B8 100 100 __0 000000000000 Error Correction Count
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
C2 _70 _58 __0 002A0000001E Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Smart Off-line Scan Uncorrectable Error Count
C7 100 100 __0 000000000000 Ultra DMA CRC Error Rate
CA 100 100 __1 000000000000 Percent Lifetime Used
CE 100 100 __0 000000000000 Write Error Rate
D2 100 100 __0 000000000000 Successful RAIN Recovery Count
F6 100 100 __0 00008AA3FAD3 Total Host Sector Writes
F7 100 100 __0 0000018A2BFF Host Program Page Count
F8 100 100 __0 000000D1C08D Background Program Page Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000  .@?..7.......?......
010: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF  ....................
020: 0000 0000 0000 4D33 4352 3034 3320 4354 3130 3030  ......M3CR043 CT1000
030: 4D58 3530 3053 5344 3120 2020 2020 2020 2020 2020  MX500SSD1
040: 2020 2020 2020 2020 2020 2020 2020 8001 4001 2F00                ..@./.
050: 4001 0000 0000 0006 3FFF 0010 003F FC10 00FB BD01  @.......?....?......
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0D98  ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 001F 850E 0084 014C 0040  .................L.@
080: 07F0 006D 706B 7409 4163 7069 B409 4163 207F 0001  ...mpkt.Acpi..Ac ...
090: 0001 00FE FFFE 0000 0000 0000 0000 0000 0000 0000  ....................
100: 6DB0 7470 0000 0000 0000 0008 6003 0000 500A 0751  m.tp........`...P..Q
110: E618 B1CF 0000 0000 0000 0000 0000 0000 0000 411C  ..................A.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 4372  @................)Cr
130: 7563 6961 6C20 0000 0000 0000 0000 0000 0000 0000  ucial ..............
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001  ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
200: 0000 0000 0000 0000 0000 0000 0031 0000 0000 4000  .............1....@.
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000  ....................
220: 0000 0000 11FF 0000 0000 0000 0000 0000 0000 0000  ....................
230: 6DB0 7470 0000 0000 0001 0200 0000 0000 0000 0000  m.tp................
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
250: 0000 0000 0000 0000 0000 48A5                      ..........H.
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 32  .../.dd........2
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 4A  .dd........2.ddJ
020: 02 00 00 00 00 00 0C 32 00 64 64 07 00 00 00 00  .......2.dd.....
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32  ...2.dd........2
040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 64 64 02  .dd........2.dd.
050: 00 00 00 00 00 00 AE 32 00 64 64 04 00 00 00 00  .......2.dd.....
060: 00 00 B4 33 00 00 00 43 00 00 00 00 00 00 B7 32  ...3...C.......2
070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00  .dd........2.dd.
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00  .......2.dd.....
090: 00 00 C2 22 00 46 3A 1E 00 00 00 2A 00 00 C4 32  ...".F:....*...2
0A0: 00 64 64 00 00 00 00 00 00 00 C5 32 00 64 64 00  .dd........2.dd.
0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00  .......0.dd.....
0C0: 00 00 C7 32 00 64 64 00 00 00 00 00 00 00 CA 30  ...2.dd........0
0D0: 00 64 64 00 00 00 00 00 00 00 CE 0E 00 64 64 00  .dd..........dd.
0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00  .......2.dd.....
0F0: 00 00 F6 32 00 64 64 D3 FA A3 8A 00 00 00 F7 32  ...2.dd........2
100: 00 64 64 FF 2B 8A 01 00 00 00 F8 32 00 64 64 8D  .dd.+......2.dd.
110: C0 D1 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 7B  ...............{
170: 03 00 01 00 02 1E 02 00 00 00 00 00 00 00 00 00  ................
180: 00 00 4D 33 43 52 30 34 33 20 00 00 2A 01 00 00  ..M3CR043 ..*...
190: 53 4D 32 32 35 39 42 34 37 52 52 00 81 04 00 00  SM2259B47RR.....
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1E0: 00 00 00 00 1A 00 00 00 00 00 00 00 10 00 00 00  ................
1F0: 07 00 00 00 01 00 00 00 02 00 00 00 00 00 00 AD  ................
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 05 0A  ................
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00  ................
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00  ................
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00  ................
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00  ................
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00  ................
060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00  ................
070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00  ................
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00  ................
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00  ................
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00  ................
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00  ................
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 01  ................
0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00  ................
0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00  ................
0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00  ................
100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00  ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22  ..............."
Ahhhhhhhhh when you mentioned the enclosure I thought no, it's hooked up with a USB at the time I saw that (was wiping it, we have been doing data clean up and changing drives around, to optimize two computers)...and that's when it hit me, the cable...just looked at it and yep, Sabrent makes the cable. Totally makes sense now. It's now in her machine on the mobo and returns normally.
Thanks!
