Greetings Computer Gods!
I've been having a very strange set of issues that very well may be connected by one root cause that I haven't been able to establish quite yet. I recently built a completely new PC and had some initial issues installing windows 10 home, but eventually was able to get in and load everything up.
However, after getting my drivers setup, some minor Normal Use things going (Browser, games, etc) I began to notice some odd behavior with my new OS.
It really came to a point when I was trying to play on a 7DtD server that a friend owned. For the life of me, I could not launch the game with EAC active. I tried everything (or so I thought) to fix it. Administrator, checked registry, drivers, comparability, uninstalled, deleted app data, etc.
Finally, someone mentioned that with the newer windows updates the error magically was corrected (something about certificate authentication). So, I go into Update and Security and find the update was at 80% downloaded. Cool. I waited a few hours. Still 80%. I decided to try and restart thinking it was something with the machine needing to fully configure the update.
I was incorrect. The machine sat on the "Restarting" screen with the loading circle for an entire episode of Oliver Stones, Untold History of the U.S. (About an hour) before I just hard reset it.
At this point I tried again to reboot and restart, thinking maybe it just hung up. Same issue. Shutdowns with fast boot worked. I then went in to see what the update was at. However, that portion of the settings would no longer open. At all. It just clicked and the box outlined it, then I would close the settings window and try again.
I then tried to repair windows with the USB install media I have. I couldn't seem to get it to load. After hours of frustration, I relented and decided to try and reinstall windows. What did I have to lose it's a fresh install.
Here's where my soul was crushed. When I get into the windows installation, I selected 64 bit, loading windows files.. a pop-up appears, asks me if I want a clean install or remove the media to boot up. I select clean install...
Blank Darkish Blue screen with a cursor. I tried multiple times, but always got the same result. I left it to sit there for 30ish minutes hoping it just needed a breather. Nothing.
Help me Tom's Hardware, you're my only hope!
I'll get as much additional info as I can once I get back home from work. I unfortunately used all my off-shift, non-sleep time banging my head against the brick wall that is my PC.
I'll try just about anything, except sacrificing a small goat. That's where I have to draw the line.
I also attempted to stop the Windows Update service using the four commands to stop it, rename the folder, and then restart it. CMD prompt responses were something of "the service is starting or stopping try again later." And then I'm pretty sure my computer hissed at me. (Not really)
