I have a few questions about the program. I tried to post on github but i can't, don't know how to do it. If there is an expert in here regarding the program would be awesome.
1. Can you set the chassis' fans profile based on your CPU/GPU, even though the program cannot take control over the hardware's fans tweaking? So basically only reading the temp sensors. I want to set up my chassis fans to ramp up and down based on GPU as well. I know there is a plugin for corsair link/command master but my GPU is AMD 6950xt which is locked. I know there is an experimental plugin for this, but i fear that might conflict with adrenaline program. So just letting adrenaline doing its think and let fan control to adjust the speed of chassis fans based on cpu/gpu.
2. Do i need specific plug in to read GPU temps, like for example HWInfo?
2.1 can i use the HWInfo plug in to set up my chassis fans for multiple hardware temps like CPU/GPU/RAM/SSD?
