G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I'm trying to setup my pc at work to remotely connect to from home.
Work PC setup:
Win XP SP2, I have enabled remote desktop on port 3389 and set it up so as
not to be blocked
by the SP2 firewall. The pc is in a LAN which connects directly to the
internet through a cisco router.
The server does not handle internet traffic. Internet is available to the
workstation even if logged localy to the
pc and not to the domain. The internal ip of the pc is 192.168.0.4
Concerning router setup, The router has an address of 82.xx.xx.xx. I set up
a port eg 4000 of the 82.xx.xx.xx
ip to point to 192.168.0.4:3389
I believe that nothing more is required, but unfortunately trying to connect
from home
using the 82.xxxxxxxx:4000 address, and specifying a local username-password
for the pc at work
I cannot connect.
Is there an error I'm doing? Is the router not set up correctly?
Please help if you know something
Work PC setup:
not to be blocked
from home
for the pc at work
I cannot connect.
