I took my friend’s PC and then played with it a while. After that I got a ridiculous idea to install my External Hard Disk as Internal and try it as Internal Hard Drive. So, I removed the DVD Power Plugs and SATA plugs and plugged it to my External Hard Disk. Then I turned on the PC, it said DISK BOOT FAILURE PLUG THE DISK AND PRESS ENTER (Not Sure But The Meaning Is Same). So I removed the side panel again and saw that power cable for Main Hard Disk got unplugged and then I plugged it in and tried again it says the same thing again. So I disassembled the PC and assembled it again exactly as I removed. Then the boot says, IDE Channel 0 Master : None and the first two channels says the same and 3rd channel is DVDRAM and at last it says CMOS Check Sum error—Defaults Loaded. And then F1 to continue and DEL to setup. I have seen in BIOS I can’t see my hard drive detected and Processor fan doesn’t spin on power. What should I do? Thanks in Advance...
