I have an Asus A7V8X-X with a Semprom2400+ on it.
I had to reset the bios, and for so, i removed the battery (with everything turned off... just don't remember if i removed of the eenergy cable). When i put the battery there again and turned the pc on,it didnt. 🙁
I remember feeling a "little" discharge when removing the battery.
Now the pc wont turn on!!
Symptoms:
- PSU fan, CPU fan are working fine
- Motherboard has its own led, that is glowing
- HD and DVDRW are getting power
- Display is not working (Monitor is going in power saving mode, by blinking led on it)
- No single beep sound from board
If the mobo is fried, then, the other components, such as RAM, VGA card and procesor will be fried too?
Help me!!!!!!!
Symptoms:
Help me!!!!!!!
