Removing PSU fan grill to Clean the fans?
If the screws which are used to take the fan grill OFF DON'T have any 'warranty void' if broken stickers on it then yes you will be fine. I Tend to use cotton swabs and compressed air to get all the dust out of my PSU.
From the picture you will be fine and NOT breaking warranty regulations with your PSU.
Hope this helps.
Wow your PSU needs a clean. Yes the warranty of that PSU will be broken if you damage (pierce) the stickers clearly stating (warranty void if broken).
If you want to clean your PSU then you will not be able to RMA your PSU if those stickers have been damaged.
No There are different screws to remove the fan grills.. (which doesn't have any warranty void if broken stickers ) That means i can remove my fan grill and clean the fan right? There wont be any harm to that seal if i remove the grill..
Hope this helps.
