removing Right-click menu options
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hi All,
Hopefuly somebody can enlighten me here. I installed a program that added
functionality to my right-click menu when I click certain objects like "My
Computer" and file directories etc... My issue is that I cant get rid of
these options even after uninstalling the program.
Can anybody help me figure out which registry key or file to edit to remove
these options?
Thanks in advance,
Chris
Chris Henderson wrote:
> Hi All,
> added functionality to my right-click menu when I click certain
> objects like "My Computer" and file directories etc... My issue is
> that I cant get rid of these options even after uninstalling the
> program.
> remove these options?
> Thanks in advance,
> Chris
Go to the following website and scroll down to the section "Context Menus
(Right Click) - Deleting entries" for the instructions.
C Page - Windows XP from A to Z:
http://www.kellys-korner-xp.com/xp_c.htm
Ronnie Vernon
Microsoft MVP
Windows Shell/User
Please reply to the newsgroup so all may benefit.
http://www.dts-l.org
http://www.mvps.org
Thank you very much Ronnie, you've been a great help.
This worked great!
Chris
"Ronnie Vernon MVP" <ronv@mvps.org> wrote in message
news:uozmT%23PYEHA.3716@TK2MSFTNGP10.phx.gbl...
> > Hi All,
> > program.
> > Thanks in advance,
> > Chris
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> http://www.mvps.org
> This worked great!
Chris
Your Welcome. Bookmark that website, MVP Kelly has a ton of good information
there. :)
Ronnie Vernon
Microsoft MVP
Windows Shell/User
http://www.mvps.org
