Removing small scratch from faceplate "window"
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    Sis
G
Guest
Guest
Archived from groups: alt.cellular.sprintpcs (More info?)
Can anyone advise on removing or lessening a slight, shallow
scratch from a Sanyo 4920 faceplate window?
It's nothing serious, of course, but I'd just as soon not see
it.
Thanks, DGI
Now, I don't know that this will work on your phone, but I used this
trick on my PDA screen...
Plain white tooth paste....rub it around with your finger.... then
wipe off with soft cloth...
This does not actually remove the scratch, but uses the abrasive in
the paste to smooth out the scratch...kinda like extra super fine sand
paper....and the paste acts like a polish at the same time...You don't
get rid of the scratch, but smooth it out so it doesn't stand out as
much.
On Mon, 19 Jul 2004 04:07:37 -0400, David G. Imber
>it.
> Thanks, DGI
I got some stuff that works fairly well. It is made by: Novus, Inc.,
Minneapolis, MN
It comes in three small plastic bottles labelled:
1 Plastic Clean & Shine
2 Fine Scratch Remover
3 Heavy Scratch Remover
Just Google: Novus Scratch Remover
On Mon, 19 Jul 2004 08:07:37 UTC, David G. Imber <imber@maniform.com>
> it.
> Thanks, DGI
Tom Brown
thombrown at san dot rr dot com
Member SCOUG, V.O.I.C.E. & SDAA
running eComStation GA + FP 3
eCS system uptime is 0 days 00:42 hours
On Tue, 20 Jul 2004 05:24:14 GMT, "Tom Brown"
>Minneapolis, MN
That rings a bell. I think I used to use that for my helmet
faceplate when I had a motorcycle.
Thanks to all for your suggestions.
DGI
Smiling Wickedly, Willa Jabir answered:
> much.
AND IT SMELLS MINTY FRESH!
of course!! you don't want it to smell bad when you got it that close
to your face 😀
On Wed, 21 Jul 2004 16:45:20 -0700, Michael Arends
>> much.
>Minneapolis, MN
>> it.
>> Thanks, DGI
Yep, you can pick up those little babies at your local CONTAINER
STORE; used for repairing/cleaning acrylic! works great for DVDs too!
On Tue, 20 Jul 2004 02:45:48 -0400, David G. Imber
>>Minneapolis, MN
> DGI
I use palm screen protectors on my pcs fone face.
They have no adheasive, and stick by static
electricity. They keep the screens scratch free,
and you can get 12 protectors, which will cover
24 screens for less than $8! And best of all, they
do NOT affect the ability to see the screen!
Presto, no scratches! I also use them on my mp3
player, and other portable electronics that have screens
that are likely to get scratched (mp3 player, etc)
Hope this idea helps!
> >> it.
> >> Thanks, DGI
