Removing Start button right click item
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Minor but irritating problem:
A piece of software I used to use installed an option when you right-click
on the START button in XP (the same option is also there when you right
click on a folder in Explorer).
I've uninstalled the software, but the option is still there. And I've
really poked around and I'm pretty sure it's all gone ...
If I go to Folder Options, File Types, File Folder, Advanced, the item is
there in the list (and not set as default) but when I select it the 'Edit'
and 'Remove' buttons are greyed out.
Does anyone know how I can zap this? I'm using XP home SP1 - yes, I know, I
will get SP2 soon, I promise .... 🙂
Many thanks
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.788 / Virus Database: 533 - Release Date: 01/11/2004
What software? Is it a secret?
Click Start | Run | Type: regedit | OK
Navigate to >>>
HKEY_CLASSES_ROOT\*\OpenWithList
HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Directory\Background
HKEY_CLASSES_ROOT\Directory\shell
HKEY_CLASSES_ROOT\Directory\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Drive\shell
HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Folder\shell
HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers
Look for entries related to [[A piece of software I used to use]]
Open regedit and do a Ctrl + F for [[A piece of software I used to use]]
Remove unwanted entries from the context menus
http://www.subvers.com/technobabble/html/tweaks/context-menus.htm
Hope this helps. Let us know.
Wes
In news:O7QgU7BxEHA.1524@TK2MSFTNGP09.phx.gbl,
its like that <itslikethat@itslikethat.com> hunted and pecked:
> right-click on the START button in XP (the same option is also there
> when you right click on a folder in Explorer).
> item is there in the list (and not set as default) but when I select
> it the 'Edit' and 'Remove' buttons are greyed out.
> know, I will get SP2 soon, I promise .... 🙂
> Many thanks
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
news:uNurP1DxEHA.2600@TK2MSFTNGP09.phx.gbl...
> Navigate to >>>
> Wes
>> Many thanks
Thanks for the help Wesley - keys deleted - and XP hasn't crashed yet! If I
could give a rep on the newsgroup I would ..... 🙂
What is [[a rep on the newsgroup]] ??
Wes
In news:%23ndL$WExEHA.2568@TK2MSFTNGP10.phx.gbl,
>> Navigate to >>>
>> use]]
>> Wes
>>> I've really poked around and I'm pretty sure it's all gone ...
>>> Many thanks
> yet! If I could give a rep on the newsgroup I would ..... 🙂
Search the registry for the exact text that you see in those context menu
items, then delete the relevant keys.
It gets a bit tricky (1) if one character is underlined,
or (2) if some of the text is right-justified.
(1) For an underline, precede the character with an "&".
Example:
Special &Function
would display with "F" underlined.
(2) For right-justified text, use "\t"
Example:
Left side text\tRight side text
would display as...
| Left side text Right side text |
Start
Run
regedit
Enter
Edit-Menu
Find...
Find what: [ <text> ]
Look at:
[Y] Keys
[Y] Values
[Y] Data
Delete the key.
Press [F3] to search for the next occurrance of <text>.
