Hi,
I was trying to replace the hinges of HP Envy 1010 and the power cable flap lock broke
need help to connect the power button cable. I tried using normal electrical tape. but it did not hold. For those who may not have an idea of the innards of HP's Envy, the power cable is connected to the laptop right next to the hinge and is around the edge of the motherboard with the display cable connector right next... hardly any place to manouvre around.
I did not want to use glue because if anything happens and I have to remove the motherboard again... I'll be stuck. The electrical tape is not strong enough to hold the cable, what should I use instead, aluminium tape, thermal tape or perhaps a better quality electrical (though it has been vetoed in a lot of posts)
Please guide
regards
Alok
Please guide
regards
Alok
